Removing Wall? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 10:19 PM   #16
GBrackins's Avatar
Rewards Points: 2,108
then I'd have to say it is load bearing. It can be removed but would need a beam to be able to support the load of the joists. ends of the beam would have to be supported by walls or columns so that loads are transferred to the ground.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-27-2013, 10:30 PM   #17
Rewards Points: 150
Just didn't know if u meant u were moving attic pull down stairs or real stairs
kaschmid3 is offline   Reply With Quote
Old 02-27-2013, 10:32 PM   #18
Ok it about a fourteen ft span what should i use two 2x8?
Mallard1123 is offline   Reply With Quote
Old 02-27-2013, 10:47 PM   #19
Rewards Points: 150
If willing u could make header exposed double 2x8 under ceiling joists with jack studs under header ends so it wouldn't be a full wall, just be a big opening about 85 in from floor yo headet
Old 02-27-2013, 10:47 PM   #20
Rewards Points: 150
And u wouldn't have to touch ceiling joists
Old 02-27-2013, 11:05 PM   #21
GBrackins's Avatar
for a 14' span with about a 12' tributary (1/2 the distance from front wall to rear wall) load I'd expect something closer to a 4-ply 2x12 (spruce-pine-fir #2), or a 2-ply 11-1/4" LVL not a 2-ply 2x8. Your beam load on a 12' tributary load (20 psf live load + 10 psf dead load) would be 360 lbs per lineal feet of beam. A 2-ply 2x8 (spruce-pine-fir #2) would be good for about a 7' span based upon these loads
Gary
Old 02-28-2013, 05:16 AM   #22
Rewards Points: 150
I'm no engineer do u may be right but even for a wall were the only thing on it is the continuous ceiling joist (2x6)
Removing Kitchen Stud Wall Below Scissor Truss smacman7 Building & Construction 3 12-12-2012 11:57 AM
Removing a load bearing wall Craig18 Remodeling 2 11-30-2012 05:41 PM
Removing part of a load bearing wall *with pics* shane2943 Remodeling 7 09-29-2012 09:31 PM
removing wall, making arc, need to determine dimensions ilyaz Kitchen & Bath Remodeling 1 03-03-2010 06:30 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
