Removing Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 10:10 AM   #1
removing wall?
i want to remove two walls that run along stairs north to south that divide my kitchen and dining room(wall 1 and 2). i will take the stairs and run them west to east at northwest corner of dining room then close in the hole and make kitchen and dining room one big room with an island in the middle for base cabinets and stove. my attic has rafters that are 2x6 that run east west and run all the way with no break. if i take out the walls should i support the ceiling joists in the attic to the rafters and if so how?
Mallard1123 is offline   Reply With Quote
Old 02-27-2013, 10:15 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
How far is the span from west to east exterior wall to exterior wall? Do you have ceiling rafters or is it a truss? Can you take a picture of your framing from the attic?
brockmiera is offline   Reply With Quote
Old 02-27-2013, 10:26 AM   #3
its about 22-23 feet wide east to west sorry about it being sideways i changed it three times with no luck
Old 02-27-2013, 10:41 AM   #4
Rewards Points: 528
No as a rule.
Are the ceiling joists one continuous board?
framer52 is offline   Reply With Quote
Old 02-27-2013, 10:41 AM   #5
brockmiera's Avatar
The pictures seems oriented correctly to me. Are you absolutely sure that you have a 2x6's spanning the entire width??? That is severely undersized. You are in SE Michigan? Detroit area? Snow load is 20-25 psf live?
Old 02-27-2013, 10:48 AM   #6
yes the joists are one continuous 2x6. Yes im north of Detroit about an hour.
Old 02-27-2013, 11:41 AM   #7
Rewards Points: 150
If I'm not mistaken u mean ceiling joists for attic r 2x6 the roof rafters look like 2x8
kaschmid3 is offline   Reply With Quote
Old 02-27-2013, 11:46 AM   #8
Rewards Points: 150
Wether it is exposed or not I would put a beam of at least double 2x 8 header going north south onto load bearing points half way over exterior wall and hall wall but it all depends on your framing load points from below
Old 02-27-2013, 11:58 AM   #9
they are both 2x6's. I would really like to not have to put a beam in if i dont have to. i can't attach to rafters?
Old 02-27-2013, 12:10 PM   #10
Rewards Points: 150
R these real stairs or attic stairs
Old 02-27-2013, 12:12 PM   #11
removing wall?
With the joist only being 2x6's, I would say that they are likely load bearing. Are there 2 walls (or beams) in the basement directly under the 2 walls you want to remove? If so, that is more evidence they are load bearing as they will be carring the weight down to the footings.
CVID is offline   Reply With Quote
Old 02-27-2013, 01:30 PM   #12
brockmiera's Avatar
Im betting wall 2 is load bearing since it looks as though it would be a common longitudinal wall.
Old 02-27-2013, 04:07 PM   #13
GBrackins's Avatar
Rewards Points: 2,108
a lot of answers depends on what your building code is. the information I'm listing is based upon the 2009 International Residential Code (your code may vary, and needs to be verified by the building department).
if you have fixed stairs to the attic then attic joists must be able to support 30 pounds per square foot live load plus the weight of building materials (typically around 5-10 psf). These shall be treated as floor joists. if accessed by scuttle or pull down stairs then 20 psf, if no storage storage (areas you won't be walking around) then 10 psf. You can view the ceiling joist span tables from this code here http://publicecodes.cyberregs.com/ic...9_8_sec002.htm
I agree with Brock, wall #2 appears to be load bearing since a 2x6 ceiling joist cannot span 22' to 23'. I'd expect the joist to be able to span around 12' to 13' (depending on species and grade of 2x6) based upon a live load of 20 psf. Also because of the location of wall #2 in regards to the basement stairs. Is there a beam in the basement under wall #2? Is there a beam under wall #1?
if you remove a load bearing wall without proper support of the attic/ceiling joists then you could experience excessive deflection of the joist which could cause cracking of the drywall/plaster ceiling and potential damage to the joists themselves (depending on actual loads).
Post back with answers to the questions and I'm sure you'll get responses.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-27-2013, 10:16 PM   #14
Not sure what your asking? I have real stairs to basement that i want to move.
Old 02-27-2013, 10:19 PM   #15
Wall 2 does have a beam under it in the basement.
Removing Kitchen Stud Wall Below Scissor Truss smacman7 Building & Construction 3 12-12-2012 11:57 AM
Removing a load bearing wall Craig18 Remodeling 2 11-30-2012 05:41 PM
Removing part of a load bearing wall *with pics* shane2943 Remodeling 7 09-29-2012 09:31 PM
removing wall, making arc, need to determine dimensions ilyaz Kitchen & Bath Remodeling 1 03-03-2010 06:30 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
