Removing A Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 06:30 AM   #1
Removing A wall
If I remove a non load bearing wall which currently connects two load bearing walls do I need to be concerned about the load points?
okeefferp is offline   Reply With Quote
Old 03-20-2012, 06:40 AM   #2
DIY staff
Rewards Points: 7,174
Typically,no---a drawing of the layout will help.
Old 03-20-2012, 12:41 PM   #3
Rewards Points: 1,092
if u r sure it is non-load bearing, then i think you've answered your question. what's to worry?
Old 03-20-2012, 06:23 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
if its definitely just a partition theres nothing structural to worry about. you just have to patch the drywall and flooring where the wall was removed
woodworkbykirk is offline   Reply With Quote
Old 03-29-2012, 10:19 PM   #5
That logic is quite sound...
diyjohn1234 is offline   Reply With Quote
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 07:35 PM
removing wall, making arc, need to determine dimensions ilyaz Kitchen & Bath Remodeling 1 03-03-2010 06:30 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
