-   -   Removing A wall (http://www.diychatroom.com/f19/removing-wall-137600/)
okeefferp 03-20-2012 07:30 AM
Removing A wall
If I remove a non load bearing wall which currently connects two load bearing walls do I need to be concerned about the load points?
oh'mike 03-20-2012 07:40 AM
Typically,no---a drawing of the layout will help.
jklingel 03-20-2012 01:41 PM
if u r sure it is non-load bearing, then i think you've answered your question. what's to worry?
woodworkbykirk 03-20-2012 07:23 PM
if its definitely just a partition theres nothing structural to worry about. you just have to patch the drywall and flooring where the wall was removed
diyjohn1234 03-29-2012 11:19 PM
That logic is quite sound...
