Removing Vinyl Trim Around Entry Door Without Breaking Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 10:20 AM   #1
Removing vinyl trim around entry door without breaking vinyl siding
I am replacing my mud room door and I need to remove the vinyl trim to access it. How do I remove the vinyl trim from the vinyl siding without breaking the siding. I don't care if I break the trim since I can replace it, but it would be difficult to repair the siding. Thanks in advance!
2vets is offline   Reply With Quote
Old 10-18-2010, 10:28 AM   #2
Chicago, IL
Michael Thomas's Avatar
Use a vinyl siding removal tool:
to pop lose the adjacent siding as required.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Vinyl siding repair sljacobs Building & Construction 5 02-28-2010 10:55 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
White vinyl windows with wood trim... crazy? rnjsbungalow Interior Decorating 5 04-16-2009 05:53 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
