Removing Stucco At Chimney Base - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 07:34 PM   #1
removing stucco at chimney base
We just discovered that we have some issues with termites coming up through the slab into our kitchen area - we discovered them coming out of the baseboard along one wall. Our home is of block construction here in Florida, and the company we're using has told us that amongst the list of things they want to address is for the stucco on the chimney to be cut away about 2 inches above the ground level, more or less in line with the top edge of the slab. I didn't know this, but apparently working their way up inside stucco is a favorite access point for termites if the stucco finishes below ground level and gives them ready access. I said I'd do the work, but after looking at the exterior of the chimney I'm not quite sure how I'm supposed to go about it. Where the rest of the house is block, as already mentioned, the chimney itself is fabricated from wood (why I don't know - cheaper and easier I guess than doing it in block as well) so I'm a little nervous of accidentally cutting too high and exposing the framework. At least if it was block it wouldn't be that much of an issue if I strayed half an inch or so above the line of the slab.
So bottom line, how am I supposed to go about this? Mark a line on the stucco about half an inch below the line of the floor level of the slab, then use an angle grinder and appropriate cutting wheel to slice through the stucco, wire screen, and whatever they used to cover the framework of the chimney? Or am I only supposed to just cut away the layer of stucco and the wire mesh it was laid on to?
Last point. You'll note in the second picture that there's a small hole on one corner which obviously needs repair. I don't really care too much about the cosmetic side of things, so what's the simplest and most effective way to patch up this hole?
removing stucco at chimney base-chimney-2.jpg   removing stucco at chimney base-chimney-hole.jpg
stephenbishop is offline   Reply With Quote
Chimney Rattles/Sways in Windy Weather cprice12 Concrete, Stone & Masonry 10 09-28-2012 11:36 PM
Removing waterproofing wood stain from stucco BearKing Painting 0 05-14-2011 06:28 PM
tuck point a inside decaying chimney base ezj001 Building & Construction 2 09-04-2010 11:49 AM
Water leak? Broken chimney stucco at gutter mrken Building & Construction 12 08-31-2010 10:51 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
