Removing Stipple From Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-27-2009, 02:08 PM   #1
OneManJob
Question
removing stipple from ceiling
I've scraped all the stipple off my ceiling in the kitchen and currently sanding it. My question: Do I have to sand it down to the drywall and putty the entire thing or sand it enough till it's smooth or can I putty over the rough texture than sand it after that? What's the best way of going about this?
jeffmarleau is offline   Reply With Quote
Old 11-27-2009, 07:39 PM   #2
PHB Construction LLC
Paulie's Avatar
Funny it must be stipple removal day. Someone just posted the same problem in Fla. As I suggested get as much off as you can, scrape or sand then "float" or "skimcoat" over smooth with drywall mud. I use the kind you mix with water "ez-sand" but drywall mud in a premixed in a bucket works just as well. Your always going to have divots or high and low spots when scraping and sanding, going over top with a thin layer of mud evens them out. Then sand your drywall "skim coat" smooth and your good to go.
Paulie is offline   Reply With Quote
Old 11-28-2009, 09:54 AM   #3
Drywall contractor
Rewards Points: 1,070
Easier if you use ready mix. Thin your mud somewhat (a cup or so of water to a 5 gal. bucket) to make it easier to spread and wipe down. It will likely take 2 coats to fill any rough areas, allowing to dry thoroughly between coats. If you cover the paper areas too it will help get the ceiling to the same consistency and give you a surface that it truly "slick". If you feel the areas you have mudded as opposed to raw drywall paper, the paper is not as smooth as the sanded joint compound. This can make the joints tend to "flash" or show through with any harsh light that hits them. "Glaze" coating the entire surface will take care of that...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Removing ceiling joists jbarre Building & Construction 5 09-11-2009 10:27 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Removing 2nd Floor Ceiling Joists BigJimmy Building & Construction 1 06-06-2008 01:43 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
