Removing A Solid Wood Pre-hung Door...... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-21-2008, 06:43 AM   #1
fastback4's Avatar
Rewards Points: 51
Removing a solid wood pre-hung door......
Thanks for your post. I see that it's smarter to just remove the pre-hung door and replace it than try to modify it to open out instead of in. So how is this done. Do i simply use a recip. saw and cut the nails holding it in?......Regards.....Tom
fastback4 is offline   Reply With Quote
Old 05-21-2008, 07:00 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Remove casing.
Yes, use a reciprocation saw to cut the nails.
- Build Well -
Old 05-21-2008, 07:13 AM   #3
Basic Installation tips: http://www.hometips.com/articles/door_install.html
- Build Well -
Old 05-21-2008, 08:45 AM   #4
fastback4's Avatar
Rewards Points: 51
removing a solid wood pre-hung door......
Thanks....Regards.......Tom
Old 05-21-2008, 01:15 PM   #5
Tom, sorry for the abbreviated posts...just have been very busy this week.
- Build Well -
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 12:24 AM
Reversing a solid wood pre-hung door fastback4 Building & Construction 1 05-21-2008 04:27 AM
Exterior Door: is there a middle ground between a factory unit & a solid wood custom? pdks Building & Construction 1 04-14-2008 11:08 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
