Removing A Small Section Of A Load-bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 06:29 PM   #1
Rewards Points: 113
removing a small section of a load-bearing wall
I want to remove about 2 ft of a load-bearing wall. the end result will look something like in the attached pic.
the red beam represents what I'll be adding for new support, right on top of it are two existing 2x4 topplates.
my question is can I use a 4x4 or does it have to be a 4x6?
two 2x4 layed flat = 3 inches thick, plus a 4x4, that's 7 inches thick. does it work that way ?
ths
oldhouse49 is offline   Reply With Quote
Old 11-15-2011, 06:34 PM   #2
Rewards Points: 582
Iwould use 2-2x8 with plywood in between to equal the rough measurement of wall thickness...
Old 11-15-2011, 06:51 PM   #3
Framing Contractor
Rewards Points: 120
No, it doesn't work that way. For a 5' load bearing opening, chances are what you propose is not adequate. What does this wall carry?
sixeightten is offline   Reply With Quote
Old 11-15-2011, 07:06 PM   #4
Rewards Points: 113
it's part of an interior kitchen wall. the attic floor joists run perpendicular to this wall on top.
Old 11-15-2011, 07:10 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
consult an engineer in your region to look at the framing of your house. codes vary from region to region do to varying wind load and snow load amounts.
the engineer can tell you what you need to do to ensure your house doesnt cave in
woodworkbykirk is offline   Reply With Quote
Old 11-15-2011, 07:14 PM   #6
Framing Contractor
A 4x4 does not work. The two top plates mean nothing with that 4x4. You need a header in there that has to be sized. Are you getting permits and inspections?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-15-2011, 07:26 PM   #7
Rewards Points: 113
I'm in SoCal, so not too much wind, definitely no snow.
I checked some framing book and online for span table, I think span for 4x4 is 4 ft, and 6 ft for 4x6. isn't this the general rule. house is one story with 1 layer of shingle. wood frame.
from: http://www.hammerzone.com/archives/w...ro_framing.htm
Header Sizing:
This table was found in a book titled Fundamentals Of Carpentry - Practical Construction, (5th Edition), by Walter E. Durban and Elmer W. Sundberg, published in 1977 by American Technical Society. Page 178.
Header Size:
Application: (Distance Spanned)
4x4 inch Up to 4' 4x6 inch 4' to 6' 4x8 inch 6' to 8'
Old 11-15-2011, 07:32 PM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I am curious, is your roof trussed or framed?
California has prescriptive designs for situations like this, you do not necessarily need an engineer for this but you should get plans and a permit.
This just safeguards you and the home's occupants.
Andy.
Andy.
AndyGump is offline   Reply With Quote
Old 11-15-2011, 07:36 PM   #9
Rewards Points: 113
Andy.
Andy.
framed. built in 1949.
Old 11-15-2011, 07:45 PM   #10
liscenced electrician
Rewards Points: 538
Cut out those two top plates. They are not needed and only taking up space. Then use at least 2 2x8s with 1/2 plywood sandwhiched in between. This will probably be cheaper than what you said anyway because you can just buy a 10' 2x8 and cut it in half
Do not do what you proposed. It will not hold
jimmy21 is offline   Reply With Quote
Old 11-15-2011, 07:46 PM   #11
AndyGump's Avatar
Rewards Points: 684
So put what you want to do down on paper, take it to the Building Department and see if it will fly.
What city? LA proper?
Andy.
Old 11-15-2011, 08:02 PM   #12
Framing Contractor
Header Sizing:
Header Size:
Are you getting permits and inspections yes or no?
Joe Carola
Old 11-15-2011, 08:10 PM   #13
Rewards Points: 113
No. not that I don't want to but the previous owner had some unpermitted add-on's and I don't want to 'rock the boat'. But I do want to do a proper job.
Old 11-15-2011, 08:16 PM   #14
Framing Contractor
Wow....what a surprise! So...two wrongs make a right? Do the right thing and have the header sized and get permits and inspections. If not and you don't size the header right and you have a problem....you deserve what you get.
Joe Carola
load bearing wall question mudpaws Carpentry 3 06-24-2011 09:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
