Hi! This is Jon on behalf of Expert Village. In this video clip, I'll take you through step 5 in our procedure for flushing the cooling system. After we've mixed our coolant, we are going to go ahead and fill up our cooling system, and if you miss a... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about step 4 in our procedure for flushing a cooling system. Once all the liquid has drained out and when you blow compressed air through the lines and air comes out, you... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I am going to take you through step 3 in our procedure for flushing a cooling system. Once your coolant has started to come out almost clear, you are going to go ahead and turn off your... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be taking you through step 2 in our procedures for flushing the cooling system. The next step is to loosen up this wing nut here, and what that will do is that will start the drain... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question “Is my coolant still good?” The first way to test if your coolant is still good is through a visual inspection, so go ahead and take a look in... Read More »
