Removing Rust From Tools - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 07:47 PM   #1
Smile
Removing rust from tools
Howdy I recently bought two pipe wrenchs that are still in working condition but haven't been taken care of. They have a lot of rust on em, do yall have any suggestions on how to remove the rust?
Colby is offline   Reply With Quote
Old 11-14-2009, 08:05 PM   #2
DIY staff
Rewards Points: 7,174
THE WORKS TOILET BOWL CLEANER--The cheap watery kind,not the 'NEW IMPROVED' thick stuff.
It will take the rust off the crustiest tools.---------MIKE----Costs about $1.50 soak in a glass or plastic dish. Have fun.
Old 11-14-2009, 09:31 PM   #3
If the recommendation is a toilet bowl cleaner, then it most likely is the lye that is in the product. This can be found in many cleaning products and you can ask your local hardware store guy what product(s) they have that has lye in it. Lye is mildly caustic and removes all sorts of crud, including rust.
Aurelius
Aurelius is offline   Reply With Quote
Old 11-14-2009, 09:36 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and if it is the lye, you could just buy some lye.
there is a method using electricity and some fluid. Seemed to work exceptionally well. I'll try to find it and post it.
found one:
Old 11-15-2009, 06:55 PM   #5
DIY staff
ACID--The Works is a fairly strong acid-I looked to see if I had a jug to find out which acid-No luck
HYDROCHLORIC ACID good old google!
Be careful this stuff reacts badly with aluminum use a glass or plastic container.
Old 11-15-2009, 07:16 PM   #6
nap
You talking to me?
nap's Avatar
so, do you add water to acid or acid to water and do you know what happens when you do it the wrong way?
Old 11-15-2009, 07:22 PM   #7
DIY staff
This stuff is not THAT strong-I add it to the water in my toilet--does that count?
Old 11-15-2009, 07:28 PM   #8
nap
You talking to me?
nap's Avatar
but how are you recommending the OP use it?
with my method, there is no acidic residue to dispose of. The alkalinity of the solution remaining is not caustic either. It will be a bucket of baking soda, ferrous oxide, and water. It can be dumped anywhere plus is will not eat the metal like an acid will. It only removes the rust.
Old 11-16-2009, 07:14 AM   #9
The OP should read the directions on the bottle.
Oh sorry it's not for cleaning tools it's for toilet bowls.
SULTINI is offline   Reply With Quote
Old 11-16-2009, 07:16 AM   #10
Old 11-16-2009, 09:15 AM   #11
Household Handyman
Rewards Points: 1,408
Don't laugh---just try it. It's cost effective (I hate cheap), non-hazardous, and easy. Go to a local farm supply store, or Tractor Supply, and buy Molasses which is used as a supplement to horse feed. Mix this 50/50 with water then soak the tools in the solution. Do Not Use this on aluminum, you can use an aluminum pan but it will permantely discolor it. And I said it was safe? I buy old tools at auction, swap meets, etc. which need TLC. I even clean old steel/iron car parts with this. It is not quick! At least one full day of soaking, maybe more. I had rather use this than any of those acidic or alkyline cleaners. Thanks, David
Old 11-16-2009, 10:14 AM   #12
nap
You talking to me?
nap's Avatar
odd suggestion but if it works, hey, why not. Any idea why it works?
Old 11-16-2009, 09:22 PM   #13
Exclamation
As the OP states he "Bought 2 pipe wrenches" (used). You can imagine they weren't toys or your average size pipe wrench. How, pray tell will they fit in a glass???!!!
Last edited by spark plug; 11-16-2009 at 09:23 PM. Reason: Typographical error (Typo)
spark plug is offline   Reply With Quote
Tags
cleaning , rust , tools
Anyone heard of COMMERCIAL ELECTRIC tools? VITAL Electrical 37 09-24-2012 09:54 PM
bathroom sink rust removal? bofusmosby Plumbing 4 11-12-2008 07:28 PM
Value of used tools Texasguy Building & Construction 6 06-02-2007 12:03 PM
Bought tools today, good or bad deal? Mr. Michael Tools 3 02-13-2007 01:39 PM
Removing spray paint from tools harold938 General DIY Discussions 15 12-17-2006 08:16 AM
