Removing/replacing Concrete Stoop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 09:00 PM   #1
removing/replacing concrete stoop
I am replacing a 36"steel door with a 60" french door. there is a 36" concrete stoop that needs to be removed and replaced with a wider one. The concrete stoop extends up and underneath the threshold. I'm not sure how the stoop ties into the block foundation and what I will end up with when I break the concrete threshold out.
I had a concrete contractor look at it but he didnt seem familiar with the design. Every house on our block has this design where the concrete extends up and under the threshold.
Any insight would be helpful.
jmilana is offline   Reply With Quote
Old 03-10-2008, 07:42 PM   #2
so-elitecrete
Rewards Points: 150
here's 1 thought,,,
the steps were built to sit ON the block rather'n adjoining the blocks,,, you might find just cutting the steps flush w/block wall's be a solution,,, shame ' those guys ' got pd & they're gone - couldda left a note, at least, huh ?
so-elitecrete is offline   Reply With Quote
Old 03-11-2008, 02:24 PM   #3
Sure, then what? I have a 1/2 concrete-1/2 frame threshold? and how will the new stoop be attached to the foundation?
Old 03-11-2008, 03:21 PM   #4
so-elitecrete
Rewards Points: 150
i wouldn't attach it to the fnd walls,,,
the cutoff part'd stay on the wall & you bld new unattached steps but maybe that's just me & my house,,, our landing & ext steps're brick over conc - NOT attached to the fdn wall.
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
