Removing Post Support/laminate Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 08:34 AM   #1
Removing post support/laminate beam?
We're doing some work on our cabin. It sits on concrete piers in the crawl space. One of the supports is right in the way of our sink. We've put up with it since we bought the place, but are wondering if there's a way to get rid of it.
I tried to capture it as best I could with my phone camera, which doesn't do panorama view as my regular camera does. The 2 pictures didn't "stitch" together as I would have liked, but hopefully you'll get the idea.
The support on the left is just to the left of the refrigerator. The other one is painted white, which as you might be able to see encroaches on the one side of our sink, and sink base cabinet, a real pain. I don't have to tell you what the wife thinks of this set up, and makes sure I know it every time she does dishes .
Is there a way to use a laminate beam to span over to the wall, taking out the white support?
Removing post support/laminate beam?-cabin.jpg
macminn18 is offline   Reply With Quote
Old 10-07-2010, 09:17 AM   #2
jlhaslip's Avatar
Rewards Points: 2,196
it would be easier to move the sink cabinet and build a new top.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-07-2010, 10:24 AM   #3
Rewards Points: 5,336
It looks like the roof rafters from each side end in the middle of the room, resting on nothing. Or is that just the picture?
Ron
Old 10-08-2010, 12:08 AM   #4
jlhaslip's Avatar
ron,
that is 2 pictures overlaid (poorly)
check the microwave.
I'd guess that the roof beams/ceiling joists are actually continuous from wall to wall.
Old 10-08-2010, 01:27 AM   #5
Rewards Points: 1,092
Mac: Easy fix. Start doing the dishes; far less hassle than what you might get into, from what I see. Wow. Can you live w/ the post moving a couple of feet? That may be doable; anyone who advises you will have to know some distances and loads, btw; snow, wind velocities (in general), etc.
Old 10-08-2010, 08:58 AM   #6
Originally Posted by jlhaslip View Post
ron,
Got it, thanks.
Ron
Old 10-08-2010, 09:42 AM   #7
Civil Engineer
Rewards Points: 4,790
It is almost always possible to remove a support column and replace it with a properly sized header. The issue is generally cost. Removal of a load bearing column and replacement with a header requires that the load be transferred to the foundation, which may require new footings or improvment to the existing footing. The header needs to be sized for the loading, which is usually done by an engineer or architect, although in some cases the lumberyard that supplies the beam may size the header for you.
You also need details for the connections of the header to the existing framing. These are normally prepared by the design engineer. And when installing the new header, you need to pay very careful attention to temporary support of the ceiling during construction.
All of this is pretty standard construction practice. You normally need a permit, check with your local code enforcement official. You may want to run a search on this site, enter "replace column" or "header" and you will see lots of threads from previous posters with similar issues.
Daniel Holzman is online now   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Replacing a 6x6 post with a laminated wood beam wazzie Remodeling 3 03-21-2009 10:18 AM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-23-2007 11:34 PM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
