Removing Post From Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 07:19 PM   #1
removing post from concrete
Hello,
My garage was once converted to a living space, so they put a square metal post (2" square and about 2' sticking out of driveway) in front of the garage bay to act as a car barrier.
Well...I have since converted the garage back to a garage and now I need to remove the post.
Was this post put in for code?
I tried a saws-all but the steel is very heavy gage and it did not work too well. I also went at the concrete with a cold chisel. The problem is that Im not sure how deep this post is, and how it is anchored.
Any suggestions on how to remove it. I never used a jack hammer before.
TIA
timcam is offline   Reply With Quote
Old 03-01-2010, 07:23 PM   #2
its probably filled with concrete if done right. you will need to rent a partner saw and cut around the post if you want to remove it completely then patch the hole.
The older I get the better I was
Old 03-01-2010, 07:34 PM   #3
Rewards Points: 5,336
Use a sawzall with a metal blade and cut 1/8" into each side. Take a hammer and hit the side of the post at the top.
Ron
Old 03-01-2010, 07:41 PM   #4
Rewards Points: 81
Exactly. Even a 4-1/2" grinder with a cut-off wheel should do it. Cut as deep as the steel goes, flush with the pavement, and then hit it with a hammer.
A 4-1/2" grinder will cost you $16 at Harbor Freight.
Jack Olsen is offline   Reply With Quote
Old 03-01-2010, 09:07 PM   #5
Rewards Points: 1,016
Rent a demo hammer or jack hammer to break of the concrete as need - then patch it over.
Removing glue from concrete? Ike64 Tiling, ceramics, marble 1 09-26-2009 03:28 PM
Removing concrete bump. brsett Building & Construction 4 09-13-2009 12:27 PM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
Concrete curing in post holes moneymgmt Building & Construction 5 11-19-2008 11:01 AM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
