Removing Porcelain Backsplash? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2008, 07:48 PM   #1
Rewards Points: 152
What is the best way to remove a porcelain tile backsplash that is set on top of drywall?
sandyman720 is offline   Reply With Quote
Old 02-08-2008, 10:37 PM   #2
Bathtub Refinisher
Hammer and chisel
tubguy is offline   Reply With Quote
Old 02-09-2008, 05:42 AM   #3
Remodeling Contractor
wolffhomerepair's Avatar
I second the hammer and chisel. Use a wide flat chisel. Be prepared to fix many gouges in the drywall afterwards.
wolffhomerepair is offline   Reply With Quote
Old 02-09-2008, 06:42 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
When you are done, one of two things will be required:
1.) The wall area of the removed tile WILL need skim coating with drywall compound.
2.) The wall area WILL be so bad that you will have to cut out the remaining sheetrock and replace it....
- Build Well -
Old 02-09-2008, 08:57 PM   #5
cut the tile and drywall out all at once.
johnrem is offline   Reply With Quote
Old 02-12-2008, 08:16 PM   #6
remodeling pro
More likely scenario... just plan on replacing the sheetrock, because it will take more work to patch/skim it than it is worth.
troubleseeker is offline   Reply With Quote
removing panel board from behind backsplash MJ1 General DIY Discussions 3 11-18-2007 09:42 AM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 12:27 PM
Backsplash advice bigboyjoel Carpentry 11 05-29-2007 08:54 AM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 08:53 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
