Removing Part Of The Woodstove Footer? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 08:47 PM   #1
Rewards Points: 402
Removing part of the woodstove footer?
It's large, the real estate agent and the home inspector both said something about how large it is. Would there be an easy and clean* way to cut some of this off to gain a little more floor space?
*clean as in it doesn't look really bad afterwords.
This is the only picture I have right now, currently there is a child thing around it so it looks larger but it actually sits back a little more.
RyanD is offline   Reply With Quote
Old 04-07-2009, 08:51 PM   #2
There is a min space needed in front & to the sides of a wood stove/fireplace as non-combustible
What do you have now?
MA Gov Fireplace/stove info:
I thought it was less then this (36")
Maybe they just mean in general
http://www.mass.gov/?pageID=eopsterm...ety&csid=Eeops
Allow at least 36 inches of clearance around the appliance to prevent combustibles from coming into contact with heat sources.
Old 04-07-2009, 08:55 PM   #3
Rewards Points: 402
Yeah, 18" from anything combustible is what I've been told. I haven't measured but it has to be much further than that.
Old 04-07-2009, 09:03 PM   #4
I thought it was 24" in front
Sides & back depend upon the stove
My stove has a heat shield which allowed me to install closer at the last house. Plus the walls were brick, with an air space to the drywall
Old 04-08-2009, 04:05 PM   #5
Rewards Points: 95
18" is the dimension that you need in front of the stove. From the door to the hedge of your hearth.
NJ Brickie is offline   Reply With Quote
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 08:48 AM
Removing part of load bearing wall? destroyer427 Building & Construction 11 04-08-2009 02:24 PM
How to get a level floor out of one that's part concrete and part wood Songbird Flooring 5 01-22-2009 11:24 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
Undercut footer billinak Building & Construction 3 03-18-2005 06:34 PM
