Removing Outside Vents - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 05:40 PM   #1
Removing outside vents
One of these used to be an old dryer vent. Not sure about the other 2 since I don't use them. What the best way to remove them and make this area look clean?
Removing outside vents-image-540450881.jpg   Removing outside vents-image-46126124.jpg
dinosaur1 is offline   Reply With Quote
Old 05-16-2012, 05:53 PM   #2
kwikfishron's Avatar
Rewards Points: 760
You'll need a couple new siding panels.
Remove the panels around the vents, remove the vents, then install the new panels.
kwikfishron is online now   Reply With Quote
Old 05-16-2012, 05:54 PM   #3
MarginallyQualified
Rewards Points: 2,464
As you will NEVER be able to match the rest of the siding...
pretty much anything you do needs to be a 'contrasting' material/color...
and you need to view it as a temporary fix until you re-side.
Old 05-16-2012, 05:56 PM   #4
Rewards Points: 760
Gotta love that vinyl siding.
Old 05-16-2012, 06:00 PM   #5
Household Handyman
Rewards Points: 1,408
Key wording here: "Not sure about the other two". So--you know one of them is an old clothes dryer vent. The other two could be a lot of different vents to release air from "who knows what". First make sure that the other two, or even one of them, is not a release area for a bath vent fan. I have seen these used for fans under homes to circulate some air, usually operated on a timer. Other than this, follow the instructions from the other posts.
Old 05-16-2012, 06:16 PM   #6
My mistake. The silver sent is needed since its connected to the hvac and one of the other white vents are also. So just the old dryer vent needs to go.
Removing Insulation from Soffit Vents cpfoutz Roofing/Siding 18 01-03-2012 09:35 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 06:20 PM
Removing tar from PVC stink pipes & metal vents? echase Roofing/Siding 4 04-06-2010 06:20 PM
Removing some vents rdmccaw HVAC 4 10-22-2008 01:00 PM
