Old 05-10-2011, 02:15 PM   #1
dpach's Avatar
removing the old wood lap siding
If it was me, I'd be using plywood, not OSB, just in case moisture ever does get under it. Plus, don't forget that humidity from inside the house will be going through to the outside as the house "breathes" (hence Tyvek/typar being a barrier to let moisture out, but not in), and OSB isn't always good with humidity. Remember to tape the tyvek seams very well, and overlap pieces a good 6 inches.
Just my 2cents.
dpach is offline   Reply With Quote
removing the old wood lap siding jbjones Building & Construction 3 05-10-2011 07:15 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
