Removing The Old Wood Lap Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 01:53 PM   #1
removing the old wood lap siding
I'm removing the old wood lap siding and foam sheathing and replacing it with osb, tyvek then vinyl siding. Any issues with moisture or anything with that setup?
jbjones is offline   Reply With Quote
Old 05-10-2011, 06:14 PM   #2
kwikfishron's Avatar
Rewards Points: 224
If you live in Oregon or Washington West of the Cascades there would be.
Where are you located?
kwikfishron is online now   Reply With Quote
Old 05-10-2011, 06:29 PM   #3
St. Louis
Old 05-10-2011, 07:15 PM   #4
Rewards Points: 224
Your plan should be fine.
Just remember the most important part to any siding job (in your case vinyl) is the prep work. If you can stand back after you install your Tyvek, flashings, tape, J, corners, accessories, etc. and be confident that no amount of wind driven rain will make it to the osb then your probably good to go. The vinyl siding is just the icing on the cake.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
