Removing A Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 08:49 AM   #1
Removing a load bearing wall
If we want to remove a load bearing wall, will a 6x9 I beam be enough to support 30ft roof span with steel pipe going from the beam to the floor on each end?
Marcyt39 is offline   Reply With Quote
Old 01-07-2013, 09:02 AM   #2
bbo
you won't get a definitave answer without a structural ( residential) engineer actually looking at the situation on site. tey'll have to do a load calculation of whats above and know what the foundation and footing and soil conditions are like below.
edit* I'm probably missing other factors as well, but you get the idea.
bbo is offline   Reply With Quote
Old 01-07-2013, 09:02 AM   #3
Rewards Points: 14,278
NO!
You need to get an engneer in there to be on site and spec what size beam and what material to use.
This is not a "I think this is strong enough" type of deal.
Bad things can happen real fast is done wrong.
No amount of pictures over the net from any place will get you any more then guesses.
Old 01-07-2013, 11:24 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
to answer your question, NOT EVEN CLOSE!
you should take the advice given above an hire a professional engineer that specializes in residential construction. They will determine the size and type of beam you need, and the installation requirements.
Better to spend a little money to determine what you need to do than to end up with structural issues which will cost a lot more money to correct.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 01-07-2013, 12:02 PM   #5
Thanks for the information, it's what I thought but was told just a beam would work
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
removing load bearing wall from first floor simvt1 Building & Construction 5 05-22-2009 09:15 AM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 09:32 PM
