Removing A Load Bearing Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 09:57 PM   #16
Rewards Points: 2,210
Depends what is above it.
Really need to talk to someone local about this.
mae-ling is offline   Reply With Quote
Old 03-09-2012, 03:56 AM   #17
having a chat with your local building dept. about what processes are in place, and what you will need to do- will probably be more beneficial than asking random people in an internet chat room if your beam is the right size.
Have you thought about your point loads? will proper support be in place down to the foundation? More to it than just throwing up a beam...
chrisBC is offline   Reply With Quote
Old 08-10-2012, 05:55 PM   #18
I did the work I mentioned above and all is well. I knew it would work, I just wanted some assurance from others, which I got from some and from some a discouraging word.
iengrave is offline   Reply With Quote
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 09:34 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
removing load bearing wall from first floor simvt1 Building & Construction 5 05-22-2009 10:15 AM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 10:32 PM
