Removing A Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 07:10 AM   #1
Question
Removing a Load Bearing Wall
I am planning on removing a load bearing wall between my living room and my dining room. I do not want an exposed beam between these two rooms. What I am planning on doing is to go into the attic and bolting a 2x6 or 2x8 to each roof joist extending down to the ceiling joist directly above the load bearing wall and bolting this new beam to the ceiling joist. Another possibility is to go into the attic and lay a 2x8 on the ceiling joist extending a couple of feet beyond the wall I plan on removing on each end. I will then use the metal hangers nailed to the 2x8 and to the ceiling joist. Will either of these two ideas work. I prefer using the first idea if possible. It will be easier getting short 2x6s into the attic compared to a long 2x8.
iengrave is offline   Reply With Quote
Old 03-08-2012, 07:37 AM   #2
Civil Engineer
Rewards Points: 4,572
I had a hard time visualizing exactly what you were thinking, a good, scaled diagram would help immensely. You also need to be very precise in your terminology, for example you refer to the ceiling joist when you may be referring to the rafters. Then again, you didn't say how many stories the house is, you did not mention dimensions, you did not mention which way the rafters (or maybe you have trusses?) run relative to the bearing wall you want to remove. All of which you should include in your scaled diagram that you post up.
Old 03-08-2012, 08:25 AM   #3
Rewards Points: 528
The correct answer is maybe, maybe not.
I am having a hard time visualizing what you are proposing also.
framer52 is offline   Reply With Quote
Old 03-08-2012, 08:48 AM   #4
I did mean roof rafters and not joist. This house was built in 1956 and is a one story ranch. It does not have trusses. I do not know how to add a drawing and do not have a scanner to scan in a diagram. If the rafters and joist do not line up, then I will lay a 2x6 on top of the joist in the attic and use the metal hangers and attach the beam from the rafters to the joist and/or the new 2x6. I hope you can picture what I am talking about. To me, it is clear as mud!
Old 03-08-2012, 08:50 AM   #5
Contact a structural engineer.
If I understand your first idea, it does not do anything to support the load that the wall is currently supporting.
M Engineer is offline   Reply With Quote
The Following User Says Thank You to M Engineer For This Useful Post:
framer52 (03-08-2012)
Old 03-08-2012, 09:12 AM   #6
Rewards Points: 528
We have a winner
Old 03-08-2012, 09:30 AM   #7
Civil Engineer
I think framer52 is spot on. The entire point of a header is that the header is supported on either end by posts which extend downward to a solid support point, either a foundation in the basement or a main beam in the basement. The header then supports the joists using metal brackets or the joists overlap the beam (above the beam), which is how it is done in older houses. The beam IS NOT supported by the joists, the joists are supported by the beam.
Maybe it is just your wording, but it sounds like you plan to lay a beam over the joists, thereby supporting the beam by the joists, which is not going to work, and would lead to the immediate collapse of your house once you remove the temporary support for the joists (you need temporary support to put in the header).
It is certainly possible to put in a flush header (flush with the ceiling). It is more difficult than installing a drop header, more expensive, and requires greater skill and caution. Regardless how you go, the header must be designed by a professional (usually an architect or engineer), and the entire process has to be though through very carefully. The flush header is still supported by posts on either end, however the joists get cut where the header goes, then reattached using brackets. Not really a good DIY job unless you are experienced.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
framer52 (03-08-2012), Gymschu (03-08-2012)
Old 03-08-2012, 10:01 AM   #8
Rewards Points: 150
Just to add another voice of reason to the matter:
The wall that is currently there supports the ceiling rafters (joists). Those rafters likely span the entire house and work in cooperation with the rest of the roof structure in:
a) bracing the exterior walls
b) supporting the roof structure
What you intend to do is to remove the support the rafters require ( its possible you also have vertical supports that come down from the peak of the roof onto this wall) then add a load on top of the rafters. This WILL cause your roof to come crashing down.
I concur with the rest of the posts here. You need to hire someone to design the arrangment as well as (judging by your lack of framing knowledge) you need to hire a contractor to execute the work.
My 2 cents. Be safe.
psilva8 is offline   Reply With Quote
The Following User Says Thank You to psilva8 For This Useful Post:
Nailbags (03-08-2012)
Old 03-08-2012, 12:37 PM   #9
Gymschu's Avatar
Rewards Points: 502
.............and threads like these show you why there are building codes.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 03-08-2012, 04:11 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 204
I understand this in a different way. I am understanding you want to nail a 2X6 from each ceiling joist to each rafter and suspend the ceiling that way. That will not work at all, for too many reasons, if this is what you have in mind you really do need someone qualified to give you some dirrections.
If you are talking about installing a 2X8 beam above the ceiling joist and tying the ceiling joist into the beam, that also will not work as a 2X8 beam is not strong enough to hold that much weight. You really do need some qualified person to give you some advise who can actually see what you have and want to do.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-08-2012, 08:22 PM   #11
Load bearing wall
Thanks for all the advice. I will remove the wall using an exposed beam and forget about the ideas I had. And Yes, I will put in a temporary load bearing wall before I take the other wall down. I will then use a 2x8 header resting on a 4x6 supports. Again, Thanks.
Old 03-08-2012, 08:42 PM   #12
Rewards Points: 528
Are you sure you are using the correct size header?
Old 03-08-2012, 08:52 PM   #13
Civil Engineer
To the ops. I do not size headers over the internet, I have posted several times why. However, you have not mentioned the length of the header, or the exact loads it is planned to support. Regardless, a reasonable guess for a dining room/living room header is 10 or more feet (mine was 11 feet). If you have a floor above, and possibly roof loads transferred to the header, a 2x8 would not even be close, as Framer52 has noted. Please get appropriate assistance in sizing the header and planning the temporary supports, you can get killed if the header and or the temporary supports fail.
Old 03-08-2012, 08:56 PM   #14
Rewards Points: 528
Dan, I hope they are listening. It can be so dangerous....
I just had to inform a customer this week that their previous handyman had screwed up their ceiling and it was in danger of catastrophe. i hope they listened....
I didn't mention, but they do seem to be too "cheap" to do it right. This time I hope they listen......
Old 03-08-2012, 09:10 PM   #15
if I use 2 2x8s with a 3/4" plywood sandwitched in between, would that not be strong enough for the header. It will be resting on the 4x6 at each end which is only a 10 foot span.
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 09:34 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
removing load bearing wall from first floor simvt1 Building & Construction 5 05-22-2009 10:15 AM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 10:32 PM
