Removing Layer Of Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 10:09 PM   #1
Removing layer of concrete
Is there a way to remove an 1.5 inch thick layer of concrete 10 inches by 20 inches in area off a 8 inch thick slab thats maybe 30 by 20 feet dustlessly ? Yeah its like a small little pit. Will those dustless surfacing grinders work or do they generate too much dust or they won't dig that deep? Will those non explosive expansive agents work (dexpan or sylentmite) or will they break through the slab ? Thanks
yako123 is offline   Reply With Quote
Old 12-16-2009, 07:28 AM   #2
ccarlisle's Avatar
Remove a pit? don't follow...
A rented jackhammer is the least dusty method of grinding concrete.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-16-2009, 07:33 AM   #3
If its not bonded to the concrete underneath a sledgehammer may crack it up to be removed
Why are you removing the concrete ?
Old 12-16-2009, 07:35 AM   #4
A jackhammer seems like it will break through all 8 inches of the concrete. I just need 2 inches off the 8 inch thick slab.
The concrete smells, i think it has something spilled on it. I figured remove a layer of it and pour concrete over it.
Old 12-16-2009, 07:43 AM   #5
So you want to remove 1.5" from a slab that was poured 8" thick?
Not a 1.5" layer poured over a 8" slab
If so...Good luck...that is a ton of work
You would be better off having it professionally cleaned
Old 12-16-2009, 07:56 AM   #6
ccarlisle's Avatar
We use a small electric jackhammer -more like a hammer drill - to break up inches of concrete in shower stalls...come witha one-inch blade bit that does nicely. But before resorting to that, what have you tried to reduce the odour - or is it just ugly-looking. Is it outside?
Old 12-18-2009, 07:45 AM   #7
I tried cleaning it with some liquid tide and water. Does the small jackhammer breakthrough the concrete or just the top layer of concrete ?
Old 12-18-2009, 07:56 AM   #8
ccarlisle's Avatar
Concrete is porous; something liquid has gotten in to your concrete andn settled there. If it smells, it's probably something organic that is now decomposing, like milk does. Use bleach or hydrogen peroxide to kill off the bacteria that are responsible for the smell. Several applications may be necessary - just pour it on and let it dry.
If you are wroried about using a jackhammer, find someone who has a concrete saw and cut a line around the part you don't like, then jackhammer that part out. It'll make some dust, tho.
Even if you crack the concrete, that can be fixed...but if you just chip away at it only little chunks will come off. Have a picture you could show us?
Old 12-18-2009, 11:20 AM   #9
Well I think using a small sledge hammer and chisel would be the best way but would require more sweat.
johnmwentz is offline   Reply With Quote
Old 08-15-2010, 03:35 AM   #10
Concrete shaver??
I had the same need to remove a layer of concrete - but throughout the entire house. I found the previous replies useful, but I wanted to ask about the various concrete shavers that are advertised on the net...has anyone tried them? How much can they remove? Are they useful for a large area?
Adela is offline   Reply With Quote
Old 08-17-2010, 09:38 PM   #11
Rewards Points: 1,910
I would find another solution to the problem rather than shaving off a layer of concrete. What is the problem you're trying to solve?
Old 08-18-2010, 02:12 PM   #12
Rewards Points: 4,586
there's enough replies on this thread to sink the sob large breaking guns are called ' jackhammers ' & can range from 60# electric to 90# pneumatic,,,smaller guns are called ' chipping ' guns &, typically, are 30# or less - air OR electric,,, rent the electric bosch ' bulldog size ' ( small ) w/point & chisel bit ),,, you could also rend a scabbler or scarifier ( walk-behind or hand-held ) but no one but a pro rental yard OR a pro has them.
have NO f'n idea what a ' concrete shaver ' is
stadry is online now   Reply With Quote
Old 08-24-2010, 08:56 PM   #13
removing layer of concrete
To answer your question jogr: I bought a stone home (built 1890) which would have originally had floorboards (as was the style of Australian cottages then). The floorboards must have become unsatisfactory (for whatever reason from rot to fashion change) and has been replaced by concrete (I estimate anywhere from late 1960's-1980). This made the rising damp (or Salt damp as it's called in the state of south australia) a problem as it bridged the original damp course and eliminated air flow. after speaking to an expert in rising damp removal, he suggested that the entire concrete floor should not be removed as it is now "part of the structure of the house". However, the floor is uneven and I do not want to raise the level of the floor by simply adding a layer of self leveling concrete. Therefore, I think a layer of concrete should be removed, I can then add some in-floor heating and cover with self leveling concrete.Job done (eventually).
Thankyou to "itsreallyconc" the chipper sounds like what I need. And yes, I meant scabbler or scarifier - but the word escaped me at the time.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 01:59 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Removing Concrete Ridge and Ground Protection on Ground Floor RayIII Building & Construction 1 10-09-2008 02:36 PM
