Removing Large Mirrors From Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 08:15 PM   #1
Removing Large Mirrors from Drywall
I have 3 large mirrors 4 x 8 taking up the entire wall in my home. I just want to remove them and repair the drywall if needed and texture and paint.
Looking for anyone with experience with this that will offer suggestions please.
danstar25 is offline   Reply With Quote
Old 08-17-2012, 08:22 PM   #2
Rewards Points: 264
Do they have frames?
We just pulled 2 out of a bathroom renovation. They were about 4 x 8 as well. Just carefully pulled them away starting in a top corner. Went slow and they remained intact, no problem. They had that black mirror mastic holding them to the wall. We wore safety glasses and gloves, just in case.
7echo is offline   Reply With Quote
Old 08-17-2012, 08:38 PM   #3
Rewards Points: 13,270
There's not going to be much left to the drywall once you remove them once you end up ripping the old glue off the walls.
Post a picture for some better ideas.
If I had to do it I'd cover the whole thing with two layers of carpet protector, it's a self sticking plastic film. Lay OSB on the floor to protect it and make it easyer to clean up after.
Wear gloves with gontlets. (long sleeves to protect your forearms)
Then try tapping in a 6" putty knife that has a metal shank all the way though the handle with a wooden handle so it can be taped on with a hammer.
Tap around all the edges you can get to so you can try and break the glue bond as best you can.
Then just try prying it off. There's about a 0% chance of it coming off in one piece if it was installed right.
There in no magic wand for this one, and no there is not stuff you can just spray on it and have it pop off.
Old 08-17-2012, 11:00 PM   #4
Picture attached.
I marked the seams in red kind of a bad picture.
anymore suggestions?
Obviously i will be moving everything out of the way before beginning..
The CELLAR gbwillner Project Showcase 112 02-17-2012 11:00 PM
I want to take a large bathroom mirror off the wall and have it cut into two smaller mirrors to hang and frame. underconstructi Kitchen & Bath Remodeling 4 02-17-2012 08:10 PM
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 11:11 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 01:34 PM
