Removing Laminate Backsplash--help! - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 10:59 PM   #16
Rewards Points: 150
Hey guys, leaving the laminate behind, (which is most likely) over your 'sheetrock' also doesn't make sense. If he wants to put a modern glass splashback or ceramic tiles, the laminate underlay is rubbish. Looking at the photos, he has already removed 1/2 the outer laminate, and needs to remove the rest.
The cupboards don't look that crash hot anyway, and particularily date the kitchen. So what's to keep? His post says he wants a modern look, well I can assure you, he ain't gonna achieve it if he leaves those cupboards in place.
He also says drywall over the lot is too thick. He doesn't want laminate by the sound of it, and I wouldn't recommend such crap, not in a modern kitchen. It's all about how much he wants to spend and what design outcome he wants. There is no easy way with splashbacks, you either do the job properly or not at all.
JoJo-Arch is offline   Reply With Quote
Tiling backsplash over laminate???? mjkpainting Tiling, ceramics, marble 46 07-31-2014 07:06 AM
backsplash 1/2 laminate 1/2 bare wall ka8byrdie General DIY Discussions 8 10-23-2010 08:50 PM
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 11:58 AM
Can I put up a glass-block backsplash over a laminate? coreyjan Tiling, ceramics, marble 1 05-24-2009 07:47 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
