Old 10-12-2011, 11:58 AM   #1
Removing Lally Column opinion
House is a ranch, truss roof. engineered floor joists on 16" ctr. meet over double 1 3/4 X 9 1/2" LVLs in semi finished lower level. LVL girder is recessed into pored foundation at one end, a lally 7' (at C/L of girder) away, and the end support along girder is 4X4 with girder butting up to basement stair raisers, 14.4Ft total length. Floor Joists are 20' long with the south joists supported 12' from girder by a 2X4 partition/barring wall separating finished family room from workshop. North joist supports kitchen/ dining room floor above. I wish to sister 2 more LVLs, same as original,to the existing LVLs inserting the one end into foundation wall, as it was poured to receive them. Notch in wall is big enough now. I will remove the lally and move it to the stair wall end of the girder and build a double top plate 2X6 knee wall out 3 feet from the end to spread the load. I will sister the new LVLs with glue and bolts as recommended. Temporary supports will be installed until project is completed.
Any comments? Loading looks OK on paper and the added bearing support from the 2"X6"X3' should eliminate the cement basement floor loading problem, but would like opinions.
msi84 is offline   Reply With Quote
3.5" lally column vs 6"x6" post shadetree Building & Construction 22 09-14-2011 09:22 AM
Lally Column StevenT Building & Construction 3 09-02-2011 04:24 PM
Hanging kayak storage rack on a lally column? whiskers Building & Construction 2 06-24-2011 06:56 PM
removing lally column in basement jimnlinda Building & Construction 3 04-08-2011 02:29 PM
Tranferring load to basement beam and lally column cooperwd Building & Construction 3 08-17-2009 11:14 AM
