Removing Joist Cross Bracing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2009, 01:33 PM   #1
removing joist cross bracing
h'lo all...first time here.
Lightning has definitely struck me twice!
Last year, I wanted to hang a ceiling fan in a family room (two-story house). I carefully "stud-finded" to be sure I was between joists before cutting the sheetrock, only to find out the stud finders won't spot cross bracing and sure enough I had a cross brace just above my hole, causing me to have to cut another sheetrock hole (and patch the previous one) as the cross brace wouldn't allow space for the elec. box that would hold the fan.
Today, in the kitchen, deja vu. Freakin' cross brace just above the hole for the elec. box. *This* time, I can't get away with cuttng another hole as it'll be painfully off-center with the rest of the ceiling. Sooo, I'm thinking of reaching up in that hole and cutting out one section of the cross brace.
What'ya think?
many thanks for all help
williemyers is offline   Reply With Quote
Old 08-11-2009, 02:20 PM   #2
Registered User
Termite's Avatar
It won't make the house fall down, that's for sure. The cross bracing enables each joist to "share" its load with adjacent joists and therefore significantly reduces the bounce or deflection in the individual members.
Why not go for a pancake box to reduce or eliminate the need to remove important framing? Box fill can be an issue with them but I'd prefer the pancake box as a trade-off instead of removing bridging.
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 10:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
Cross bracing Drakeheating Building & Construction 14 11-11-2008 11:10 PM
Cross Bracing 2X12 joists jamiedolan Building & Construction 10 09-30-2008 10:35 PM
X Brace, Cross Brace Removing ejensen1 Building & Construction 2 04-16-2007 06:08 AM
