Removing Hammer Set Concrete Anchors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2016, 09:56 PM   #1
Rewards Points: 1,606
Removing hammer set concrete anchors
I need to remove a sprinkler timer mounted on an exterior concrete wall.
For some reason, the last owner mounted the plastic timer box onto the concrete wall with four hammer set concrete anchors.
How would you remove these? I can't think of a way to do it without using a pry bar and that would end up tearing up the plastic box as well.
Unless I can somehow fit sawzall with a flat metal blade behind the box and cut the anchor off flushed. Which is possible.
Is there another way to remove the box without damaging it and not leaving any part of the metal anchors inside the wall?
miamicuse is offline   Reply With Quote
Old 07-02-2016, 10:29 PM   #2
joed's Avatar
Rewards Points: 12,002
Re: Removing hammer set concrete anchors
Grind the head off. A small die grinder or dremel tool should fit in without damage to the box.
Old 07-02-2016, 11:40 PM   #3
jlhaslip's Avatar
Rewards Points: 980
Agreed with the grinder/dremel but I might try to drill the centre part out to minimize the amount of dremel work.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
joed (07-03-2016)
Old 07-03-2016, 12:34 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
Unless you are saving that sprinkler box to send to the museum, I'd me using some brute force to remove it and then just cut off what is left...then use a punch to push the remaining stud into the wall...then patch
Old 07-03-2016, 08:33 AM   #5
joed's Avatar
I would agree with the drill option. I didn't think of it at the time. A center punch to set it in the pin and then drill away.
Old 07-03-2016, 10:46 AM   #6
Rewards Points: 1,248
Drill it was my first idea.
These are just a different kind of rivet. And rivets are best drilled out.
Center punch first to give yourself a stable starting point.
ED
de-nagorg is offline   Reply With Quote
Removing Glue/Mastic from Concrete Klawman Flooring 25 06-11-2015 02:34 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Removing concrete sealant and leveling Leisha70 Flooring 3 08-05-2012 12:06 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Concrete wedge anchors n0c7 Building & Construction 11 09-09-2011 12:47 PM
