Removing Granite Backsplash - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 09:28 AM   #1
Rewards Points: 87
removing granite backsplash
I recently had a new granite countertop installed w/ a 4" granite backsplash. I want to remove the backsplash so I can have more space to install an elaborate tile backsplash.
I've been told just to rip it out (careful enough not to hurt the counter).
Should I use the caulk remover to try and soften and break the connection/adhesive?
Thanks.
momof2labs is offline   Reply With Quote
Old 03-14-2010, 09:35 AM   #2
protect counter, fig on chunks of splash and drywall because it is probably on with silicone. lottsa drywall patching. I wouldnt use any chemicals around tops unless top suppliers give ok
The older I get the better I was
Old 03-14-2010, 05:10 PM   #3
Rewards Points: 87
Thanks for your quick response!!!
Tags
granite backsplash , removing backsplash
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 11:58 AM
New granite in existing construction, I want to keep my backsplash nam11b Building & Construction 5 04-15-2009 01:50 PM
Granite backsplash over beadboard? Asil65 Building & Construction 10 03-23-2009 11:02 AM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 08:53 AM
