-   -   removing granite backsplash (http://www.diychatroom.com/f19/removing-granite-backsplash-66734/)
momof2labs 03-14-2010 10:28 AM
I recently had a new granite countertop installed w/ a 4" granite backsplash. I want to remove the backsplash so I can have more space to install an elaborate tile backsplash.
I've been told just to rip it out (careful enough not to hurt the counter).
Should I use the caulk remover to try and soften and break the connection/adhesive?
Thanks.
tpolk 03-14-2010 10:35 AM
protect counter, fig on chunks of splash and drywall because it is probably on with silicone. lottsa drywall patching. I wouldnt use any chemicals around tops unless top suppliers give ok
momof2labs 03-14-2010 06:10 PM
Thanks for your quick response!!!:)
