Removing Foam From A Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 08:45 PM   #1
removing foam from a floor
What is the easiest way to remove foam backing from an old carpet install from a concrete basement floor? I've tried ammonia and acetone but it requires more scraping than I have the strength for. Thanks for your time
danadawn is offline   Reply With Quote
Old 06-19-2011, 09:06 PM   #2
jschaben
Rewards Points: 502
Hi - thing that comes to my mind is an oscillating tool similar to the Fein Multi-Master. They get a mint+ for the Fein but there are a lot of knock-offs out for a LOT less money, including a couple from Harbor Freight.
Personally, I have a Dremel multi-max and that, with a stiff blade scraper attached would make short work of that job.
http://www.cporotarytools.com/factor...cgid=multi-max
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-19-2011, 09:10 PM   #3
sander
Its almost 500 sq ft though. I was wondering if a floor sander would work but then also wonder if I have the strength to handle that
Old 06-20-2011, 08:07 AM   #4
Rewards Points: 4,538
we use a regular 110v floor buffer & 80mesh screens w/sand on the floor,,, belt sanders will ' load ' the sandpaper belts w/foam - not a good idea,,, another plus is that you get to walk behind it like a man & not have to crawl about on the floor
removing thinset from old wood floor annskigirl Flooring 1 05-21-2011 06:41 AM
Removing floor tile? dvatt Flooring 6 01-31-2011 04:07 PM
Insulating basement floor with ridged foam diamand General DIY Discussions 8 01-31-2011 01:08 AM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Removing 9" x 9" floor tile Mikon Remodeling 3 10-10-2007 10:38 AM
