Removing A Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 04:01 PM   #1
Question
Removing a Fireplace
Hi, I'm looking at removing a fireplace that separates our kitchen and our living room. It would really open up the rooms.
The fireplace is a funky shape all brick, it is gas fed, and goes up through the roof. It does not appear to support anything. I hope to have pictures posted up soon.
Any insight as to what I should be looking at to get started. Thanks all.
- Wil
wilvelas is offline   Reply With Quote
Old 05-03-2011, 04:17 PM   #2
Rewards Points: 5,336
You will need to open all the walls to the roof that surround the chimney.
You will need to remove the chimney from the roof to the first floor.
Close the roof off and shingle to match the current color.
Reframe the walls opened for demo.
Possibly reframe the floor and ceiling joists.
Add matching flooring if needed.
Paint all the new sheetrock(maybe the rooms)
Have all the brick and mortar carted away.
Realize that removing a houses asset will reduce the value somewhat.
Ron
Tags
fireplace , remove
Removing concrete stone from fireplace - Need How To Advice cheese1478 Remodeling 3 08-29-2012 09:02 AM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 03:28 PM
Removing a pre-fab fireplace insert MarkinTN1 Remodeling 1 10-09-2009 11:20 PM
Removing Gas Fireplace - Please Help Max Power HVAC 2 11-20-2008 08:08 AM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 05:01 PM
