Old 12-19-2010, 06:34 PM   #1
removing exterior wall studs
can i remove a portion of an exterior wall stud, if i support it with a header. my plan is to remove about a foot of the stud near the floor, and re-support with 2x12 or 2x10 spanning the studs left and right of the one that is removed?
rkling is offline   Reply With Quote
Old 12-19-2010, 06:56 PM   #2
Are you talking about a single stud or cutting out the bottom foot or so of a whole wall?
If just a single stud, a 2x10 header spanning at least two studs on either side of the "victim" shoujld suffice, I'd think.
*disclaimer: not a pro, could be full of it*
Hohn is offline   Reply With Quote
The Following User Says Thank You to Hohn For This Useful Post:
rkling (12-19-2010)
Old 12-19-2010, 07:03 PM   #3
hohn, only removing a portion of single wall stud. thx 4 response!
Old 12-20-2010, 01:10 AM   #4
It all boils down to "what is above?" and "What is the stud spacing now? 16" OC?" Since a 2x10 header (usually double boards) is sometimes used over 3' doors, I am certain that a double 2x10 is gross overkill. I would guess that a double 2x6 would do. That said, if you never check w/ an engineer or experienced builder, use 2x8's.
The Following User Says Thank You to jklingel For This Useful Post:
rkling (12-20-2010)
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Removing studs under a load-bearing header (with pictures) sbazzle Remodeling 5 04-23-2010 02:28 PM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 11:35 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
