Removing Concrete Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 03:41 PM   #1
Rewards Points: 264
removing concrete question
I have a 21' by 2' in length run of cement/concrete that I want to remove. It is about 3.5" deep. I have a ball peen hammer with a long handle. What is the easiest way/method to break it up? This was poured next to my original driveway to make the size of the planter smaller. I want to remove it to expand the planter back to it original size. Any thoughts?
Pawl is offline   Reply With Quote
Old 11-25-2011, 04:07 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
A ball peen hammer, you have to be kidding Rent an electric jack hammer.
Coastal South Carolina
Old 11-25-2011, 04:08 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,208
jackhammer... problem solved.. if the concrete is green a sledgehammer might work. by green i dont mean the color i mean very recently placed
woodworkbykirk is offline   Reply With Quote
Old 11-26-2011, 12:53 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
Well....I wouldn't say a jack hammer is necessary....
I removed an 8'x33' patio using a sledge hammer and pry bar....took me about 8 hours....nice workout.
At a minimum you need a sledge hammer.....
The other option....go to home depot and rent one of those day workers.
ddawg16 is online now   Reply With Quote
Old 11-26-2011, 04:19 AM   #5
Rewards Points: 104
A jack hammer is definitely the way to go, but a sledge hammer and pry bar are good tools for a homeowner to have anyway, so, in my opinion, you wouldn't be out anything to pick those up, and give it a try. Once you have some cracks in it, it usually breaks easier if you can pry up a chunk, and block it, so that you have an air space under it. Either way, whether a sledge hammer and prybar or a jack hammer, put on a good set of goggles before you do anything else.
Old 11-26-2011, 06:09 AM   #6
Depending on it's age, there might be asbestos in the cement. Asbestos was commonly used as a binder. As a precaution wear a good respirator and use water to keep down the dust.
fitter1 is offline   Reply With Quote
Old 11-26-2011, 10:40 AM   #7
Rewards Points: 502
don't forget the trailer you'll need to haul it a place that will accept the concrete.....or you could just keep at it with the ball peen hammer until it is fine gravel.
forresth is offline   Reply With Quote
Old 11-26-2011, 10:46 AM   #8
Framing Contractor
I hope this is a joke???? Or has common sense gone out the window.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-26-2011, 11:18 AM   #9
A Little Of Everything
Rewards Points: 1,364
What you need more than a huge hammer - or certainly a jack hammer - is a big pry bar to get one corner of the concrete up off the ground. Unless it has re-bar, concrete is easily broken when it has no support under it.
DrHicks is offline   Reply With Quote
Old 11-26-2011, 12:14 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Pawl you certainly have your issues with concrete. You know full well a ball-peen hammer isn't the way to do that job and you are just screwing with everyone here. In addition, you have made enough prior posts to tell that you are not as stupid as you want to appear. April is still five months away.
Go rent an electric jackhammer and get to it if you really intend to remove the concrete you just poured in September. Come back with any serious questions you may have and we will be glad to help.
The Following User Says Thank You to Bud Cline For This Useful Post:
rjniles (11-26-2011)
Old 11-26-2011, 12:27 PM   #11
Ironlight's Avatar
It can be done. Don't forget The Shawshank Redemption.
No wait, that was a rock hammer. Nevermind.
Ironlight is offline   Reply With Quote
Old 11-26-2011, 12:30 PM   #12
Rewards Points: 87
Bobcat/backhoe with jackhammer attachment?
huesmann is offline   Reply With Quote
Old 11-26-2011, 01:27 PM   #13
JOATMON
ddawg16's Avatar
This is what I did in one day using a sledge hammer and pry bar.....big as pry bar.....makes for a real good workout. I have lost 20lbs since I started working on my 2-story addition.
And you will need one of these....cost me $365...includes drop off and pick up....no real time limit on how long you can keep it....but be aware that everyone seems to think that it's a community trash can....
Old 05-03-2013, 07:14 PM   #14
Rewards Points: 79
I know I'm a little late on this, but what size sledge did you use?
rpearlberg is offline   Reply With Quote
Old 05-03-2013, 07:49 PM   #15
Roofmaster
Rewards Points: 2,210
This one is easy. Since it is only a few feet wide all you need is a helper, a shale bar , a sledge hammer, and a piece of 6 x 6 to use as a fulcrum. You lever it up, and give it a shot with the sledge. It will break right up. DrHicks is right you have to hit it with no support underneath. "Ball Peen Hammer", yeah right.
Concrete Question moemiter Building & Construction 2 07-14-2011 11:00 AM
concrete block wall question cbzdel Landscaping & Lawn Care 12 09-07-2010 10:36 PM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 01:59 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
Concrete question Daniel O'Connor General DIY Discussions 1 11-22-2004 02:54 PM
