Old 12-12-2006, 01:13 AM   #1
mike2006
Default Removing Collar ties
I am new to this board and would like some advice about possibly removing collar ties in my attic. I added a second floor to an existing ranch house. The span along the middle of the house is 24 feet wide by 40 feet in length. My carpenter installed collar ties at every other rafter about 4 feet up from my attic floor. I would like to know if I can remove them, or possibly just cut them shorter and move them up closer to the ridge. I have no idea if this is possible, but I would appreciate if sombody could help me out.
The span is 24' wide
The length is 40' wide
The rafters are 13' long
The rafters are 2" x 8"
The ridge is 2" x 12"
The rafters are 16" apart
Collar ties are 4' down from ridge
Collar ties are 9' 7" long
Collar ties are 2" x 6"
The distance from floor to ridge is 6' 5"
The rafters run the same way as the floor joists
It is a perfect triangle design
Mike2004 is offline   Reply With Quote
Old 12-12-2006, 08:50 AM   #2
It sounds like overkill. As long as you keep the ceiling joists, (Attic floor beams) in you can move them up. These are there to keep the rafters from pushing the walls out, but the ceiling beams also do that if nailed properly. You can replace them with 2x4s and move them up to save 2 more inches.
sjrhome is offline   Reply With Quote
Old 12-12-2006, 01:36 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If they are there, then there is a reason for it...(example: the ridge beam and rafters sound undersized and this was a way of compensating)
Solution:
1.) Add knee wall framing and collar ties to each side (sandwiching) the rafters at a higher location.
or
2.) Create plywood gussets and install them at a higher location on EACH rafter.
Do not move them so far up that you defeat the purpose of the collar ties...
MOST IMPORTANTLY:
I would recommend that you have someone knowledgable, view the rafter layout on site to see if there are other structural areas that could be affected ... BEFORE you start to do anything up there.
- Build Well -
Old 12-13-2006, 08:27 AM   #4
One other thing that will be key here is the size/spacing of the joists and their span (ie - is it the full 24' or is there a load bearing wall somewhere in the middle). You're pretty much going to need 2x10's of the best quality/strongest species of lumber or else 2x12's to span that kind of a distance if the attic will be used just for storage; engineered lumber will probably be required if you have you eye on converting the attic into living space (as your desire to remove the collar ties implies).
Collar ties are generally for the benefit of the rafters, though, and your rafters sound more than big enough. Well, unless your roof is concrete tile and less than 3:12 in slope... you might actually need 2x8 rafters in such a case.
allpraisebob is offline   Reply With Quote
Old 12-13-2006, 10:29 AM   #5
mike2006
Default Collar ties
I am using the space for storage only. The attic floor joists are 2" x 10". They are 24ft long. There is no load bearing wall in the middle. I have standard roofing shingles. There is only one layer of shingles.
P.S. The collar ties are only 3 feet off of the floor which makes it very difficult to walk up there.
Old 12-13-2006, 07:18 PM   #6
General Contractor
joasis's Avatar
Th above advice is all correct, but I will add one thing to consider with "knee bracing" a rafter.....you must have structure (wall that will bear the load) under the knee bracing, or you will have problems later with sagging ceilings. It sounds like you won't really have a problem, but do get some advice from a pro...it may be worth a lot to spend a few bucks getting an opinion.
joasis is online now   Reply With Quote
Old 12-16-2006, 03:48 PM   #7
Default ties
sjrhome is right.
If the rafters are 2x8's @ 16" o.c. in a moderate snow zone, horizontally spanning 12 ft and the attic floor joists are properly nailed to them and also properly nailed where they might lap at middle of the house, then the ties in question are not properly placed and can be moved.
When ties are in the lower part of an attic space they aren't really "collar ties", they're "rafter ties", and are doing the same thing as the attic floor joists which is preventing the top plates of the walls, as well as the rafter bottoms, from spreading. In this case, the ties appear to be redundant.
Proper "collar ties" would be installed in the upper 1/3 of the attic space in order to prevent the tops of the rafters from separating at the ridge. That means they can be installed as high as the bottom of the ridge board at every third rafter pair. Most codes require 2x6 collar ties.
Such a modification would be compliant with the requirements of the 2003 IRC.
mighty anvil is offline   Reply With Quote
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
So now were coming into the part of the home that we haven’t yet completed. This is the path to the guest bedroom. This stairwell was a closet. Now you can see that the walls have been sheetrocked and some of the tape has gone on the nail holes... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
collar ties explained? troycalm Carpentry 13 04-04-2007 04:16 PM
raising collar ties ajoantmug Building & Construction 9 03-18-2007 07:15 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 06:16 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 01:53 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 11:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
