Removing Closet / Building Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2009, 01:03 PM   #1
My house was built in 1890. One of the bedrooms is very small (12' x 8')There is an upstairs closet off this room that juts out into the hallway. I assume it was added later. I want to remove the closet and build a wall in its place and make the small bedroom a walk-in closet.
My questions:
Would this be a weight-bearing wall?
Once I remove the closet, how would I go about building a wall in its place?
beespost is offline   Reply With Quote
Old 10-23-2009, 06:15 PM   #2
We pick these?
You'd have to check to see if any ceiling joist or roof bracing, etc... is resting atop the wall to know if it's load bearing. You'll probably get your best advice by posting a diagram or picture of what you have to work with. If there's a common wall between the small bedroom and the other bedroom with the closet between you'd just cut a door opening into it. Like I said, a simple diagram or pictures would really help. You "can" alter structurally load bearing walls if you do it properly, which entails obtaining a permit and meeting applicable codes.
NailedIt is offline   Reply With Quote
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
Running romex along a wall in a closet Red Squirrel Electrical 16 10-02-2009 09:44 PM
Building a 1/2 wall in a basement? BowDown Building & Construction 1 07-27-2009 03:13 PM
building a heavy wall crmotoxr Building & Construction 2 01-31-2009 10:05 PM
Building Wall Over Floor bradarth Flooring 2 07-11-2005 11:15 PM
