Old 11-15-2006, 05:10 PM   #1
Default Removing cement walls in basement / replacing with I beam
I want to remove the cement walls in the basement and replace it with an I beam that runs the distance of the basement. Someone told me it couldn't be done or shouldn't be done. After he left, I looked at it and I have plenty of room to put the beam and have the same head clearance that I have now. I want to open up the basement. My questions are could I do this, should I do this, and how much does that usually cost or can I attempt to do it myself? I am in Michigan if it makes any difference at all.
bbockstanz is offline   Reply With Quote
Old 11-15-2006, 05:27 PM   #2
Log-Style Home Contractor
North Country's Avatar
The short answer would be to have a qualified contractor look at it or possibly consult with an engineer.
North Country is offline   Reply With Quote
Old 11-15-2006, 06:16 PM   #3
For safetys sake (and piece of mind) you will probably need to have an engineer look at it and figure what size beam and how many supports it would take to hold up the house. I would not consider this a DIY project. Consider the equipment and manpower it would take to get the beam in place.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-15-2006, 06:25 PM   #4
concretemasonry's Avatar
Even if you find a beam with the proper strength, you will have consider the deflection and what it will do to the existing walls and how the floor will "bounce". Strength is not the same a deflection.
Your engineer can give you some ideas of what it will be like.
concretemasonry is offline   Reply With Quote
Old 11-15-2006, 06:54 PM   #5
General Contractor
joasis's Avatar
Here is another take on the issue. A concrete or block wall is distributing the weight across the area you wish to place a beam. Now while the weight of the house is not insurmountable, as far as placing the beam, you have to consider if there is sufficient support when the weight is transferred from the footing to piers.
An experienced contractor, and I don't mean just maybe, can give you a preliminary idea of expense and feasability. If you can find an engineer in your area (building engineer), it may be worth the fee to have him look. Be prepared for a lot of head shaking.
joasis is offline   Reply With Quote
Old 11-15-2006, 08:32 PM   #6
How many stories is the house? (is it a ranch house)
How long will the beam be?
Are there bathrooms above this area?
What is the condition of the exterior founadation walls?
When was this house built?
redline is offline   Reply With Quote
Old 11-16-2006, 12:44 AM   #7
this is only a one story house with basement. The beam would ahve to go roughly 30 to 35 ft. the wals are pretty structurally good. And I believe the house was built in the 50's but I am not sure. I know I have taken a lot of weight out of the house by removing plaster walls and redoing them with drywall because we opened up some spaces and closed others and jsut other general remodeling. Do you have any idea or even a very rough estimate on the cost to have someone do it.
Old 11-16-2006, 02:20 AM   #8
Based on your info, you'd be around 4500-5000. Assuming it could be done.
Old 11-18-2006, 11:43 PM   #9
core your slab have an engineer inspect the house, basement and concret core then closely adhear to his recomendations.
ncor is offline   Reply With Quote
Old 11-19-2006, 08:31 AM   #10
General Contractor
joasis's Avatar
Drilling a hole in the footing area / floor will determine depth, and overall condition will suffice. Actually drilling a core sample would be great, but what exactly will you use for a comparison? Aged concrete is notorious for being harder then a woodpecker's lips, and may break with a strength of 10,000 psi, but may shatter under a load also. The overall condition of the concrete, depth where the lally collumns would be placed, and weight supported will determine if this is feasable.
More On This Topic
If moving walls is in your plan, there are several things to consider. You want to consider what is in the wall. Is there electric in the wall? Is there plumbing in the wall? Where is it? Where can you move it? Can you take it out? What would be the... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
On behalf of Expert Village, my name is Gregg Tauriello. I'm from Suite 16 Studio, and I'm here to talk to you about soundproofing for a recording studio. Okay, I'm going to show you the inside of a standard wall. This is 2x4 constructions; this is a... Read More »
Hello! My name is Grady Johnson, I’m a professional painter, and today I represent expertvillage.com. Now I want to talk a little bit about maintaining your house with pressure washing. Pressure washing your house is a big event, and usually it... Read More »
Cracked Basement Beam lpcon Building & Construction 12 04-12-2007 09:47 AM
Question about steel I BEAM in basement djohns10 Building & Construction 2 02-22-2007 11:41 PM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 08:36 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 07:06 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 03:07 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
