Removing A Cement Step On Outside Of House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2009, 07:58 PM   #1
Removing a cement step on outside of house
On the front of my house, I have a cement step leading to my front door. I am planning on put a deck type step, using composite materials instead of the cement step. I am wondering If I need to remove the old cement step, or can I build right over it?
Also, if I have to remove it, what is the easiest/best way to remove it? I am worried about damaging the foundation of my house while removing the old cement step.
Any advice would be greatly appreciated. When i get home tonight, I will take some pictures of the step, which will maybe better help you understand what I am talking about.
Thanks!
Vikeologist is offline   Reply With Quote
Old 06-17-2009, 08:52 PM   #2
Will the composite be raised up over the cement steps?
You can't put it directly on the cement, that will hold water
Do your research on the composite
Lots of complaints, problems
Old 06-18-2009, 05:55 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Vikeologist View Post
....or can I build right over it?.....
The risers would be all out of balance
e.g. assume your setup is now:
  • 10" to 1st step
  • 10" to front door
To cover the concrete step with 1” composite. The result would be:
  • 11” to 1st step
  • 8 ” to front door
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-18-2009, 12:14 PM   #4
right now I have to step up to get into the door of the house. I want the top landing to be even with the door, so you can walk right in.
By building over it I meant, adding a step, and making the top landing/platform, higher than the current cement is. It wont be directly on the cement, but will be built above it, the risers will be higher than the top of the step itself.
Old 06-18-2009, 12:19 PM   #5
Tool Geek
PaliBob's Avatar
I'm Having trouble visualizing. Can you post a Pic?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-18-2009, 01:33 PM   #6
Where are you located? Snow area?
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
EXcessive moisture in house geema HVAC 5 09-10-2008 12:18 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
House Wrap - removing vinyl siding to install wrap roo747 Building & Construction 9 11-01-2007 06:27 PM
