Removing Casement Sash - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 02:20 PM   #1
Removing casement sash
Hello,
I have to paint some trim around two windows on the second story of my house. I don't have a ladder long enough to reach, neither do my neighbors. My other option is to remove the window sash so that I can easily reach. I don't know how to do that. Can you fine folks help me out? Thanks
Paul
madison75 is offline   Reply With Quote
Old 08-09-2010, 08:31 PM   #2
Rewards Points: 5,336
Post a picture of the hardware. What you do depends on which window you have.
Ron
Old 08-10-2010, 05:54 AM   #3
Casement sashes are the easiest to remove, unless it is OLD. Most hardware has connecting pins that simply pop out with a screwdriver, there may be a stop screw keeping the plastic hinges in place. With the screw out, the hinges slide out of tracks.
Old 08-10-2010, 04:45 PM   #4
Rewards Points: 1,910
They are also easy to drop when trying to remove and reinstall from the inside so be very careful.
Removing Glass of Casement Window JPM General DIY Discussions 3 02-09-2010 10:16 AM
replace sash with casement window fiostech Building & Construction 2 11-11-2009 04:08 PM
Window sash runner/liner jds1900 Remodeling 3 04-26-2009 08:35 PM
Problems with Pella ProLine double-hung breaking when clenaning jpsmith Remodeling 5 04-15-2009 12:09 PM
Sash Window renovation DED Carpentry 1 05-25-2005 01:32 PM
