Removing Bottom Chord From M Truss - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2010, 02:46 AM   #1
Removing bottom chord from M truss
I have a dropped 7 foot ceiling in my kitchen, above which are scissor trusses. I want to remove the dropped portion and sheet rock the bottom of trusses for a cathedral. Problem: the eating area has a 7 foot 7 inch ceiling with M trusses and one of these is 8 inches into the area I want to cathedral. Can I attach a sister truss in scissor configuration and remove the bottom chord of the M truss? The kitchen and eating area are on the back of the house (under just half of the M and each scissor)
katschilling is offline   Reply With Quote
Old 05-20-2010, 05:55 AM   #2
I would not recommend changing a truss without an engineer checking things out. Every part of atruss is important, and changing one part can upset the whole truss.
Old 05-20-2010, 09:15 AM   #3
i would think laminating an EXACT replica of the scissor truss onto the m truss would work
The older I get the better I was
Old 05-20-2010, 09:52 AM   #4
Household Handyman
Rewards Points: 1,408
I'm with Bill on this. Every point on a truss where two boards meet is either a "suspension" point or a "compression" point. It's sort of like making something by stacking up dominoes, or playing the game "Jenga". Once you remove one point that is critical to any other point you have a weak spot. David
Old 05-20-2010, 10:41 AM   #5
Thanks, all. I have had a few general contractors tell me, "Oh, no problem. We will just sister in a cathedral truss to the regular one." But a structural engineer said, "a truss has to be engineered", which I figure means that the whole truss has to be placed as a unit, not "pieced" in. Can that be done from below without removing the roof? Kathleen
Old 05-20-2010, 11:03 AM   #6
Old School
Willie T's Avatar
I would NOT "sister", or in any way attach the scissor truss to the existing truss. Doing so might very easily transmit loads and stresses in directions they were not intended to handle thus possibly compromising the structural integrity of both trusses.
Willie T
Old 05-20-2010, 10:37 PM   #7
Registered User
Rewards Points: 526
" Can that be done from below without removing the roof?" Yes, after engineering. I have done this a half dozen times, using the engineered nailing pattern and length of fasteners required for liability. It will be listed on your papers. Also have sistered trusses next to rafters from inside. Check with your local engineers....
Be safe, Gary
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
Floor Truss Project ChrisMax Building & Construction 8 04-27-2010 03:19 PM
Stick Rafter not attached to bottom chord & sagging, new Trusses Robear Roofing/Siding 12 10-16-2009 04:41 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 12:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
