Removing A (block) Wall - Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2007, 06:24 PM   #1
Rewards Points: 29
Removing a (block) wall - questions
I might want to remove a wall from my (all block construction) triplex. It's a short (about 5 foot) wall near an outside corner that originally made a small pantry.
1) How do I make sure this isn't a load-bearing wall before I knock it out?
2) How do I knock it out?
3) How do you clean up the place where the wall intersected the other wall, and make it look pretty afterward?
It looks like I would just get a sledgehammer and go at it, is that about right? I don't think there are any wires or pipes inside...
Thanks!
Genhawk21 is offline   Reply With Quote
Old 09-07-2007, 10:39 PM   #2
Rewards Points: 5,336
This sounds like a load bearing wall to me. I'd pass on the sledge hammer until someone with some knowledge about the structure can be called in.
Ron
Old 09-08-2007, 04:20 PM   #3
Rewards Points: 29
Ok, thanks - who would I ask to look at it? A general contractor? An engineer? I'm new to these things...
Old 09-08-2007, 06:26 PM   #4
Weekend Builder
Crackers's Avatar
Try city hall; here you can get the original plans for your home. Cost $50.
Crackers is offline   Reply With Quote
Removing Texture From Interior Wall JustWondering Remodeling 3 05-28-2007 05:56 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Free standing block wall foundation 3DPiper Building & Construction 4 10-19-2006 08:42 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 09:34 PM
