Removing Asbestos Tiles With A Heat Gun - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 04:52 PM   #1
Rewards Points: 370
removing asbestos tiles with a heat gun
I recently had a contractor over to get a quote to remove asbestos tiles (9 inch square asphalt tiles) from my basement. He suggested I just use a heat gun to loosen the adhesive and do it myself since he figured I was a DIY'er. I've read a bit online about it and some places seem to suggest only doing it for small area's (1-3 tiles) but I need to do ~1000 sqft, is there a reason to not do a large section with just a heat gun, other then time? I'm debating between heat gun and flooding the basement, but I can't flood it that well because of the wooden steps that I don't want to ruin and the utility room is in the basement, so I can't just put down an inch of water.
MLMIB is offline   Reply With Quote
Old 03-31-2011, 06:08 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
The chances of you releasing a non-negligible amount of asbestos fibers from the tile or the cutback are virtually nonexistent. Its not friable like pipe and duct insulation is. That said its up to you to decide how cautiously you want to proceed. I would personally seal off any ducting and doorways, wear a N95 mask, and wet as I go with a garden sprayer with soapy water. Heat may help for stubborn tiles, but with a good scraper, you should be good for most if not all the tiles. Just try to break them as little as possible.
iminaquagmire is offline   Reply With Quote
Old 03-31-2011, 07:03 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A heat gun for 1000 square feet would be needless to say very labor intensive.
I'll tell you how we have done it in grocery stores and malls and hospitals and it is quick and easy for the most part.
Use a propane torch. Heat the floor tile while a helper uses a long handled scraper to peel up the tiles. Two guys can easily remove about four hundred square feet per hour.
Here's a picture of the torch. You can buy one at Lowe's or Home Depot or any Farm Store.
http://www.harborfreight.com/propane-torch-91033.html
XXX
Old 03-31-2011, 07:51 PM   #4
Rewards Points: 5,336
So you'll get the tiles up by flooding the basement?
Why do you need to remove the tiles? It's easier to just cover them up.
Ron
New Project Started, Fear Growing -- Wall Tiles and Asbestos Mastic? itcanadian Remodeling 5 03-19-2011 12:11 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Radiant heat and asbestos tiles sixsix General DIY Discussions 2 07-23-2010 09:00 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
