Removing 4x8 Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 04:58 AM   #1
removing 4x8 window
I'm replacing an older 4x8 double pane window with a 6' sliding glass door. I'm just trying to figure out the easiest way to remove without damaging the unit. It's an old window from the 70's i'm guessing, and it doesn't appear to have an easy way just to remove the glass...
So it's about 8 feet off the ground outside and I need to know the safest way (other than those cool suction cups) to get the window out safely...
Our plan of attack was the run a sawzall along the outside studs to remove any nails/screws and slowly try to bring it back into the room. Hopefully that is an alright idea...
Thanks for any advice...
-chris
smallcrpt is offline   Reply With Quote
Old 09-12-2009, 08:33 AM   #2
Remodeling Contractor
leave the nails in the bottom. Then cut the others as you plan. Then tilt the window in and now cut the bottom nails.
Old 09-14-2009, 07:04 PM   #3
we almost did it right, but just the two of us.. we just couldn't handle it... and it dropped, but luckily it just broke half of the pane, so cleanup was easy. thanks for the advice
Old 09-14-2009, 11:46 PM   #4
Rewards Points: 1,016
Don't feel badly, that's a heavy window - I recently removed and replaced two windows 8' wide and 60" tall, and it was a handful for three guys...
Removing window from detached garage HELP mjkpainting Carpentry 9 08-02-2009 06:19 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Removing window frosting CouldaShoulda General DIY Discussions 1 02-25-2008 11:20 AM
