Removed Aluminum Siding, Have A Few Questions. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 02:36 PM   #1
Removed Aluminum Siding, have a few questions.
After living in our 1920's era home for a few years, we decided to take down a few pieces of the aluminum siding to have a look. As I had figured the bottom cedar clapboard will need to be replaced, but overall the condition looks fantastic!
My question is about the vapor barrier. Before the previous owner had the aluminum installed there was tar paper on top of the cedar. I think this may have contributed to how well the cedar has been preserved. How important is it to add a vapor barrier under the existing clapboard? I've remodeled parts of the interior and there is no insulation, and no vapor barrier.
Is it possible to add this between the studs from the inside, or should the clapboard be removed? We plan on insulating between the studs when we remodel the rest of the house.
Living in the NW I would assume this is important for the house to have to fight against the moisture we have in this region.
HenryG is offline   Reply With Quote
Old 06-29-2009, 03:09 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
A vapor retarder needs to be on the warm in winter side of the wall. In your case it needs to be as close as possible to the interior wall surface. It definitely should not be toward the exterior where cool air may condense moisture on the inside of it.
Old 06-29-2009, 03:38 PM   #3
So before I put up drywall I should have a vapor barrier installed after the insulation?
Old 06-29-2009, 05:50 PM   #4
Household Handyman
Rewards Points: 1,408
HenryG, that is the purpose of the brown "Kraft paper" that is on one side of fiberglass insulation. It sounds as if you are going to be installing insulation, and if you use rolls or batts, they can be bought with the paper attached. If you are blowing insulation in, I'm not sure how the vapor barrier is applied. The paper side goes inward to the heated side of the home for a vapor barrier. Thanks, David
Old 06-30-2009, 07:10 AM   #5
Yes. There are several ways you could insulate, but if you use fiberglass batts, you either use kraft faced with a treated paper retarder or unfaced and then staple 6 mil poly directly over the studs and and the batts. Do not do both. Only one vapor retarder.
Old 06-30-2009, 03:51 PM   #6
My post was probably confusing.
I guess that is what I was wondering is if using the "paper" on the insulation is sufficient enough as a vapor barrier as long as I staple it to the studs before applying the drywall.
I just wasn't sure if in this climate (30 miles from the coast in the pacific northwest) I would need additional protection or not.
Thanks for all the help guys!
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
