Removeable Steps For Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 07:18 AM   #1
Cool
Removeable steps for exterior wall
Hi,
I am about to permanently cover my roof terrace, which will remove access to another small existing roof (I can currently get up there via step ladder from uncovered terrace).
My neighbour's, single pitch, tiled roof abuts the terrace, and is accessible (from the side of the terrace) and easily strong enough for careful access by an adult. Once on this adjoining roof I would be able to climb up for maintenance access to the small roof mentioned.
But...I need to fix some steps into said wall to do this.
Shouldn't be permanent as I can't risk the kids heading up there when they're older.
The best ideas I had so far:
1. knock out, and cement in steel guide tubes, for slotting in thick-gauge steel re-bar, bent into 'n' shapes.
2. same, but bigger holes / sleeves, and using thick wood, inserted to almost depth of wall.
Does anybody have any thoughts?
With thanks
Jon
Jon Jarratt is offline   Reply With Quote
Old 04-17-2013, 08:29 AM   #2
Rewards Points: 13,296
Post a picture.
None of this makes since to me or sounds like a good idea.
Basement Steps Branden Building & Construction 13 12-07-2012 08:14 PM
Installing stone steps timcsi Landscaping & Lawn Care 2 12-19-2011 11:00 PM
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 09:32 PM
Re-staining inside steps saggdevil Painting 10 09-20-2009 07:40 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 09:06 PM
