Remove Viynl Add Tile - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 04:55 PM   #1
remove viynl add tile
i had viynal in my master bath and i want to add tile i removed the vinal but there is a layer of thin set on the floor,
although it is smoothe do i need to break it up before putting down tile and if so how is the easiest way of doing this
mrvalerio is offline   Reply With Quote
Old 05-10-2013, 05:21 PM   #2
Roofmaster
Rewards Points: 2,210
Are you sure it is thinset, and not the backing off the tile? Usually you will see serpentine lines where the adhesive was put down with a notched trowel if its just the adhesive.
Old 05-10-2013, 05:44 PM   #3
remove viynal add tile
@ Jagens no sir it was not tile that was down it was viynal floor and there is some glue resedue but the gule is not a problem to remove,
its the smoothe layer of white thin set as we used to call it,that is what i dont want to remove because its hard to take up
if it helps my home was built in 1984
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Remove sealant from ceramic tile Ann Hebert Tiling, ceramics, marble 4 09-30-2011 09:35 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
Remove embossing leveler residue from unglazed tile? retrohouse Tiling, ceramics, marble 3 08-15-2010 11:56 AM
How to remove vinyl tile for asbestos sampling? RDS Remodeling 6 08-14-2008 06:24 PM
