Remove Soffits Above Cabinets And One Of The Boards Is Cut...need Fix - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2014, 09:14 AM   #1
Rewards Points: 320
Remove soffits above cabinets and one of the boards is cut...need fix
There were these ugly soffits all of the kitchen. I removed them and adding crown, painted and the cabinets are looking much better except for this one spot where they cut the fake beam to fit the soffit in. I doubt I'll be able to match the stain plus it's at the odd angle but what other option do I have? Any ideas? Thanks
Remove soffits above cabinets and one of the boards is cut...need fix-2014-10-26-10.10.50.jpg   Remove soffits above cabinets and one of the boards is cut...need fix-2014-10-26-10.10.33.jpg
RyanD is offline   Reply With Quote
Old 10-26-2014, 09:18 AM   #2
Rewards Points: 4,464
where is the broken off piece ?
Fix'n it is offline   Reply With Quote
Old 10-26-2014, 09:32 AM   #3
Rewards Points: 320
No idea, probably long gone from when they did the soffits original (20 years ago)
Old 10-26-2014, 09:40 AM   #4
ok. i thought that you broke it.
Old 10-26-2014, 03:21 PM   #5
Davejss's Avatar
Rewards Points: 678
Repair the broken piece and then get three or four small cans of stain and play around with mixing a bit of each until you get what you need.
Davejss is offline   Reply With Quote
