Remove Section Of Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 10:36 AM   #1
MrD
Remove section of load bearing wall
Hi, I want to remove two studs on a load bearing (I assume, because its the only wall at a half way point of a house) wall to create an opening between my kitchen and living room area. This is on the upper floor so there is only have a roof above. The roof is pitched, I think with the peak more or less over the wall I want to remove. Is this something I should consult a structural engineer about?What I actually want to do is create a window or an opening between the two areas, not necessarily a door and I'm wondering if anyone has any suggestions or pointers.
Thanks a lot.
MrD is offline   Reply With Quote
Old 07-14-2009, 10:44 AM   #2
Do you have a picture of the area?
Is there an attic & can you see if there are any studs that support the roof from this wall?
Also can you tell if any ceiling joists (2x's) end on this area?
Basically you need a header & cripple joists to carry the load
Is there a wall below this wall?
Once you install the header & new support framing there has to be something below to support the new weight distribution
You may also need a temp support while installing the header
The Following User Says Thank You to Scuba_Dave For This Useful Post:
zare34 (09-06-2011)
Tags
load bearing wall
Load Bearing Wall??? please help shenmon Building & Construction 6 01-24-2009 10:07 AM
Load bearing wall or not? tv4184 Building & Construction 19 01-04-2009 01:12 AM
How to determine if it's a load bearing wall? tripower Building & Construction 8 12-30-2008 09:42 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
