Remove Old Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By lenaitch
Old 10-04-2016, 01:37 PM   #1
Rewards Points: 174
Remove old exterior wall
Recently demo'd a small bathroom that was likely added when an addition was put on the house.
Can anyone tell by looking at the pics if I'd be ok in removing the wall with the door (from bedroom) with partial board/OSB from inside the space.
Want to make sure it's not structural or load bearing. There's one spot that has three 2x4s together that I assume is structural? Would I be OK removing from that spot down to the window?Remove old exterior wall-img_0938.jpg
tb582 is offline   Reply With Quote
Old 10-04-2016, 02:44 PM   #2
Rewards Points: 1,191
Re: Remove old exterior wall
There is no header over the door at all. So I don't think that wall could bear a load if it tried. But don't take my word for it. I've never taken out a wall.
mathmonger is offline   Reply With Quote
Old 10-04-2016, 04:49 PM   #3
Rewards Points: 174
So thanks but no thanks?
Old 10-04-2016, 07:19 PM   #4
Rewards Points: 174
Want to make sure it's not structural or load bearing. There's one spot that has three 2x4s together that I assume is structural? Would I be OK removing from that spot down to the window?Attachment 312842
After reading this article section "Determining Header Type" http://homeguides.sfgate.com/need-he...ing-70152.html
I realized I didn't provide a proper picture of the header and top plates. So here ya go:
Old 10-04-2016, 09:27 PM   #5
You've got it all ripped open. Take a look. What's above that wall? Are there joists for the second floor there? Are the ends of the rafters sitting on top of that wall, putting all the roof weight there? Is there a gable directly above there? Exterior walls do tend to be load bearing.
Old 10-04-2016, 11:47 PM   #6
Rewards Points: 174
The attic is above that wall. Will take a look and see what I can see.
Old 10-08-2016, 10:54 AM   #7
Rewards Points: 174
Removed some more of the drywall - here's some updated pics.... I don't think this wall is loaf bearing anymore; thoughts?
Old 10-08-2016, 10:26 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 444
Well, it appears it's not a load-bearing wall anymore.
Msradell likes this.
lenaitch is offline   Reply With Quote
can i remove Amitabh Building & Construction 0 06-08-2016 07:42 PM
How to remove shower pan? timnancyk Plumbing 17 01-11-2016 04:06 PM
need to refinish me pressure treated deck AND remove cabot SPF - NEED INPUT Kirchf Painting 0 05-27-2015 12:19 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 10:09 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
