Remove Half Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 03:56 PM   #1
Rewards Points: 26
Remove Half Wall
My wife and I would like to build a closet in an existing space in our bedroom where the old closet used to be. I have removed 1 bar that ran across the width of the closet and a small bar that ran from a wall (3 ft Height) to the one end. This short bar was used to hang items like shirts that were not full length.
I believe this wall used to run full height and was cut in half to support the short bar. By looking at the pictures attached can anybody advise if it is safe to remove? Would it affect the structure in any way of the home? We would like to removed this in order to accommodate our design.
Thanks!
booboohead is offline   Reply With Quote
Old 01-26-2014, 04:04 PM   #2
Rewards Points: 13,694
It should just be any empty space in side of it.
Going to be stuck with a drywall and a floor repair in that area.
Old 01-26-2014, 08:31 PM   #3
Rewards Points: 236
cut a hole in the drywall. if you see nothing inside, electrical, piping, whatever. take it out.
Fix'n it is offline   Reply With Quote
Old 01-28-2014, 02:03 PM   #4
Rewards Points: 336
There's no way that's structural, because it doesn't run up to support anything overhead. The only thing to be concerned about is what Fix'n it said; make sure there's nothing inside. If there's electrical it can likely be dealt with DIY without much hassle. Piping would be more of a pain.
JKeefe is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Securing a Half Wall cbaur88 Building & Construction 18 02-18-2013 05:43 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Addition of a Half Wall in a Carpeted Room pete0403 Flooring 6 11-12-2012 09:55 PM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 04:05 PM
